It is currently Mon Jul 21, 2025 5:12 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jan 21, 2007 8:18 am
I've used Zpoxy both ways prior to FPing...
1) sanding down to bare wood
2) Leaving a very thin, sanded smooth surface of ZPoxy
You have to make a commitment to either way. Having part of a surface sanded to bare wood while the remainder is coated will show an inconsistant surface and color once the final finish is completed. Either way works but I prefer to leave the surface coated. I get a smoother surface and I like the color and pop that Zpoxy imparts.
PostPosted: Sun Jan 21, 2007 8:20 am
JJ's correct....leaving patches of wood bare will lead to a patchy finish.
PostPosted: Sun Jan 21, 2007 8:37 am
[QUOTE=JJ Donohue] Having part of a surface sanded to bare wood while the remainder is coated will show an inconsistant surface and color once the final finish is completed. [/QUOTE]
This will also be a problem if you sand throuh the finish and down to the wood later, and it is another reason I don't like the idea of leaving a layer of epoxy under the finish.
